Gearbox leak
luke89
hey guys i have an 04 Prado 364xxxkms turbo diesel 5 speed manual i have a small leak coming from the top of my gearbox nothing major the drops are about 2cm diameter after sitting for for 12 hrs i rather get it fixed sooner rather than later any ideas
Can you pinpoint exactly where(front, middle, rear) it is coming from?
Do you take it off road at all?
It you haven't already, pop some cardboard under it and it will help give you a better indication.
It could be the speedo drive o-ring, selector plate gaskets or may even a breather issue.
    3. 14
      Hi from Wagga
    6. 2
    7. 2
    8. 2
      Engine oil dipstick reading
    10. 1
      Landcruiser 13B Engine Swap
