Posted (edited)
Hey guys,
Finally began modding my Aurion. She's already been debadged, has tint booked in and (yes, I know it's not really a cosmetic mod) she is booked in to have reverse sensors fitted at Toyota as I'm not a fan of the blindspot. After the tint I plan to go for some slimline weather shields and finally some rims. Before I begin window shopping, I just want to confirm rim sizing. My understanding is they are 5x114.3, is this correct? If so, they seem to be the same as Falcon wheels.
Cheers
Edited by GreenFence
Posted (edited)
The PCD is the same as Falcon however the bore size is different . Toyota has 60.1mm and Ford has 73.1mm. Therefore you would need to run with concentric spigot / hub rings to reduce Falcon 73.1mm down to Toyota 60.1mm. I would suggest using steel or alloy but avoid plastic / nylon. Never fit and drive your car without using the spacer rings. Dangerous and unsafe !
Edited by TIDYWAZZA
      Android auto
    2. 9
      Android auto
    3. 1
      Turboed Corolla Overbuilt?
    4. 3
    5. 3
    6. 0
    7. 18
    8. 5
      Tow bar
