Hilix V6 Starter Issue or something else?
nerdski
Hey humans.
Got a issue trying to diagnose on 2005 Hilux 4L V6 GGN25R. if any one could suggest what it might be 🙂
I was driving my ute round all day with no dramas with Battery & start up. THEN:
> I stop at shops. Come back got in car and when to start the car and got nothing no starter click, no turn over & Engine + Oil + Battery light come on.. But i have full power to all accesories still.
>  I got a tow home and could clutch start it off the tow truck ramp. I turned it off after jump start.. Then turn it on again and it started! Then tried my luck again turning it off and it was DEAD on second attempt to start - as mentioned above.
- Checked all blade fuses ✔️
- Battery Brand new & charged ✔️
- Starter motor replaced in 2016✔️
  -  Swapped Starter Relay fuse and still dead (with engine + battery + oil light still on.)✔️
Could it be the a Immobiliser relay
> Is alternator or would it be the Solienoid attached to starter, or a wire Ground
BTW my ute is actually for sale if anyone is interested. Details on Gumtree DM if interested.
Edited by nerdski
      Drive shafts
    3. 10
      front brake calipers
      Drive shafts
    7. 315
    8. 10
      Dashlight dimmer
