2003 Toyota camry altise v6
Hi guys I bought 2003 camry altise v6 so the the left quarter panel signal blinker isn't working even when I swapped over the working one from the right the left low beam head light isn't working either I tried to undo the bulb from watching a YouTube video buy it won't turn its stuck any suggestions on what I should do now that be great but I dont know anything about cars so obvious I should take it to a mechanic im just wondering if anyone had this issue ?
  • 10 months later...
 i also have a 2003 altise and having blinker problems, everything works , lights, tail lights, parkers, reverse light even have hazards lights working , but cannot get blinkers to work, even my mechanic cannot work it out , even had answer from toyota themselves they say its my compresser  i have changed all fuses, even had a new blinker arm component installed but still no blinkers, test lights on fuses in car and under bonnet all working.. . would you have the answer im looking for before i get a auto electrician to look at it.. thanks...
      Drive shafts
    3. 10
      front brake calipers
      Drive shafts
    7. 315
    8. 10
      Dashlight dimmer
