1992 1hdt both blinkers flashing together
Hi Tony,
I don’t think so. When operating the hazard switch the dash lights are quite bright. When I turn either blinker on they are not as bright. I think it is an earth issue, maybe in the blinker switch. I’ll pull it out tomorrow and clean it with contact spray unless someone has a better idea 😁
OK, pulled out the blinker control stalk and cleaned it with contact spray, problem still there. Disconnected the hazard warning switch and no blinkers at all. Not sure if the blinker relay gets its power through the hazard switch, if so this could be normal. It’s looking like a trip to the auto electrician as without a cct diagram I’m just chasing my *****.
