2018 SL. Reversing camera display stopped being animated.
thisguy
I have a 2018 Camry SL Petrol. Until a few months ago the lines in the display for the reversing camera were animated. Now they’ve stopped being animated and an exclamation mark in a diamond is in the top right corner of the display.
I’ve tried looking in the instruction manual to try and change it back to being animated but I haven’t found how too. Does anybody here know how to do this?
I don’t know if this is coincidental, but I had a new car battery installed yesterday. Still no change to the reverse camera display. Could it be from some software update?
Edited by thisguy
Hello,
I had this happen to me when the battery connector worked itself loose and intermittently disconnected. I worked out the dynamic guidelines needed to be recalibrated after the battery disconnected. In my 2016 Camry I did this by turning the steering wheel full lock in one direction, then turning it full lock in the other direction.
I can't remember 100% what gear I needed to be in, but I think I needed the engine to be running and either in Park or Drive. I did my calibration in my driveway so I don't think the car needed to be moving at all.
1 hour ago, allanl88 said:
Hello,
Thanks. I'll try it and see what happens. I did since have to buy a new car battery as my old one went flat. Maybe the old battery getting old caused the problem?
Edited by thisguy
Just tried it. Didn't seem to work. Maybe I'm doing something wrong?
Apart from trying the same thing in a different gear and/or moving slowly as you turn the steering wheel each way I don't know what else to suggest.
The battery being disconnected was what caused my issue.
