Help - Blowing white smoke
Mark1204
 Hi, I have a Toyota Kluger 2013 and its blowing white smoke. In the beginning it was just a bit especially when you started the car but it has increased now while im driving to.  I have taken it to a mechanic and he says the valve stem seals need to be replaced.  Has anyone had this happen before and is there any other options I can try to fix it? If there is no other option but to replace the valve stem seals, does anyone know of anyone in Perth WA that could quote to fix it?
Search on this Forum or do a Google Search with the search term of white smoke on startup or similar. It is definitely NOT valve stem seals for the Toyota 2GR_FE engine.
The white smoke is due to oil vapors being drawn into the intake manifold. The PCV valve needs to be cleaned/replaced as a starting point. You can also try to desludge the engine and an oil change using a quality known brand synthetic oil and a new filter cartridge.
Most likely there is significant oil sludge build up in the front valve cover. A definite proven solution is that the cover needs to be removed and thoroughly cleaned.
Also go back to the proven old school approach of regular oil change intervals of 5000 kms/6 months.
Ok so you were right there was a fair bit of oil sludge build up in the valve cover. The cover was removed thoroughly cleaned, the oil changed then a desludging additive put through and then the oil changed again.  The oil looked allot cleaner at the end.   Unfortunately I am still getting white smoke on start up.   Do i need to leave it a while and will the smoke eventually go away or is it time to replace the PCV valve now or would anyone know if there is something else I need to do now?   Any help would be appreciated.
Not a Kluger guru, but white smoke has always meant water / coolant getting into the combustion chambers, it's steam. Oil burns with a bluish smoke. If the sludge in the valve cover was a whiteish colour then that is also a sign of water, in the oil.
Herb
1 hour ago, ozieagle said:
Herb
KLuger and the Aurion both are fitted with the 2GR-FE engine. Specific engines have specific issues. White smoke particularly on start up for the 2GR-FE engine is commonly due to oil vapour being sucked into the intake via the Positive Crankcase Ventilation [PCV] valve. The PCV valve needs to be checked and cleaned or replaced, as required.
The 2GR-FE engine is also highly susceptible to oil sludge build up especially in the valve covers when not properly maintained with regular oil changes using quality engine oil. The known solution is to remove the front valve cover and give it a thorough clean to remove the oil sludge build up particularly the area relating to PCV. This enables the oil to drain away more efficiently and effectively to reduce being drawn into the PCV valve.
I have previously cleaned the PCV valve a number of times and eventually I ended up replacing it. Something else to do is to clean the vacuum hose between the PCV valve and the intake.
So I replaced the PCV Valve and for a couple of days, it was great no smoke.  Then yesterday the white smoke was back when I started the car only.   It seems to be only when I start the car now, which I suppose is  bonus.   Any other suggestions?  Your help is greatly appreciated.
Have you also given the vacuum hose a clean i.e.with a spray of de-greaser. Maybe be also give the throttle body a cleaner which may help to remove any oil related film in the intake. something else that i did was to fit an oil catch can which has since been removed.
The real solution to fix this white smoke issue was to thoroughly clean the valve cover and also any oil sludge build up in the valve train.
Something else that i did as temporary measure and to confirm that it was oil sludge build up issue was to temporarily disconnect the PCV valve from the valve cover. I taped off the pcv valve so it was unable to suck in an excessive amount of air. I also blocked the valve cover hole opening with some filtering material.
The white smoke on start up should stop within a few weeks. If it continues, I would do another clean of the front valve cover with particular attention to the section leading to the pcv valve.
  • 4 weeks later...
      Ggn15r Transmission dip stick
      Torque settings for 2014 Toyota RAV4 transmission pan bolts
    3. 8
      Hello from Arizona
      How to reset CV36 single button key fob
      Fortuner off-road & touring equipment sale
    7. 2
      Coolant leaking from radiator?
    8. 2
