camber wear or wheel alignment?
SIL3Nt
After just having my D2's installed for just over a month, i checked my front wheels and noticed all the tread on the inside is gone. I dont know if its the camber or wheel alignment( when i got my d2's installed the guy said to go get a wheel alignment after a week or so). I havnt had time to get a wheel alignment so yeah.
here a some pics
front right
front left
any help will be appreciated
thanx
the thing about coilovers and any kind of stiff suspension setup is that your car can now corner fast and with that you probably go around corners fast because you now can. tyres will wear quicker and if you did not get that wheel alignment it will make the tread run out faster.
Edited by kcorro
The floor in your theory though Marcus is that would cause excess wear on the outer side of the tyre.
This is most definitely camber wear, and perhaps an incorrect toe setting. Both of which would be corrected by a $45 wheel alignment.
      Aurion tyres
      Aurion tyres
      Aurion tyres
    5. 2
      Just joined
    6. 2
      2016 Hilux SR5 Coolant Issues
    7. 2
    8. 2
    9. 1
      ZRE182 Nudge bar
