BNO
    2010 Aurion Touring
    Brisbane
BNO's Achievements
  1. bump
  2. Hey guys, Im needing some help, the girls Celicas waterpump has crapped out for the windscreen washers. Now Im fortunate to have a brother who works for Autobarn however I was told today they cant get them in as they only supply up to 94. Suggestions were made to go to wreckers and the likes however, you dont actually know if it will or wont work. Does anyone know where or if anyone has a spare one they would be willing to part with or could direct me in the right place to go. I am in brisbane but as long as i can sort this out and suprise her thats the main thing. Cheers BNO.
  3. They sure do! Finished Where do I get these and how much! They are the most bad ***** looking lights ive seen!
  4. my sound system sounds bad *****...the train horns are going in another project car later on... im about to do a few minor mods. Set of those in 19slowered coilovers exhaust may have procured myself a decent supercharger too. The rims though are going to have some serious concave and stepped out a bit. Oh and im also looking at getting LED tail lights and projectors too! And possibly a matte black paintjob
  5. Hey Bud, where did you get those tail lights, they are bad *****! Looks the goods too! Dan
  6. ok after discussions with my mate at toyota its not a wise move to cut that bumper, so back to the drawing board. when there is a way there is a ninja to appear!
  7. it will still be structually sound dont worry about this, he builds hotrods for a living but the problem is you try and fit the housing ofr a K3LA (google that) the bottoms fit ok, its just mounting of the top housing. I might ring my mate at toyota and ask him, I know alot of performance cars that are street legal run with out them due to their intercoolers falling into place, but their will be gussets in place along with reinforced bits... **** im considering getting a bull bar if i head out west for work so issue will be clearly fixed. Id roof mount but think that might cause some issues, plus i gotta put my HIDS in yet... oh and get a new bumper where some ***** threw a steel rod through my car on the gateway because i was doing the speedlimit.
  8. Hey Guys, Its been a while since ive posted, been busy with life as usual. Im about to make an addition to the aurion however, there is an issue with space between the front bar, that foam and that lovely steel bumper bar. Now, what i need to know is the follow. If the bar is cut and re modified then have rolled 4mm tube put in its place to harden or toughen the structure will that be an issue. 2 is the foam a big issue in regards to the front bar. I cant say what im doing it for yet as its a supprise :D Just wear ear plugs. Cheers Dan
  9. hey mate :D No sun roof, firewall plugs are all in from what i can see, ill have them check and inspect the plugs and plenum tomorrow when it gets serviced as well as the air con pipe well the only time the seals were off were when i had some hail removed, however they were on as normal so :S the windscreen hasnt been removed either... who knows whats going on but either way its annoying. cheers Dan :)
  10. Morning Guys, Has anyone had the issue where the foot wells have filled with water (not alot just enough to wet the carpet). In the past i had a bottle leak however, over the last 2 weeks my front foot well back passenger well had filled with water, I pulled the car apart let it dry out, put all the seals back on right etc... went for a drive in teh rain yesterday low and behold its wet again... I know it only started happening when i had the hail dammage removed so im suspecting it could have been the guys that pulled the trim off the roof, but it doesnt explain why its not wet up top just down the bottom... goes in for a service tomorrow so im going to let the service centre look at it. cheers Dan :)
  11. ^this man speaks truth! yeah, the wing rattles like a bitch! Also, back parcel shelf too! Deaden the boot, lid, numberplate, also underside of the parcel shelf, topside as well! If your rocking low hz tunes you will find it will rattle no matter what... ie at 30hz anything and everything will! So what you need to do is get deadener STP BOMB (way better than dynamat) line the back shelf with that, and STP gold) speak to drew at northfield moorooka for it he is the only stockist!
  12. Thats the first thing I did, un less i missed it i Didnt see if a 9.5inch width would fit.
  13. Evening! Im about to get a set of wheels for my Aurion, however Im unsure if 9.5" width will fit? If not whats the widest I am able to fit. I have spoken to a few people but I get mixed answers so :S Cheers Dan :)
  14. I dont even run speakers in the back. But spacers are the way to go, id also suggest packing some dacron in under the trim too to stop any kind of rattles... but also sound deaden too!
  15. BNO
    hey mate,
    if you dont mind me asking who did your install?
    if you want i can have a look at whats causing the rattles in the front doors.
    1. the mdf rings have come loose from where they mounted have started a bit of vibration.
    2. it could be the door plastic resonating, which can easily be fixed with some deadener.
    email me today at work ...
