maba
    2001 Prado
    Melbourne
2,538 profile views
maba's Achievements
Community Regular
Community Regular (8/14)
  1. Hi Maba  I agree about poor service from dealerships.  I purchased a new prado in 2018 with an ABS bull bar and an extra battery no one thought to tell me that the extra 120kg on the front would require heavy shockers.  So I drove out of the dealership with an roadworthy vehicle.   It took six weeks to admit the problem and fix.  I had to pay half.   And then after my last service they changed the fuel filter and forgot to prime the fuel pump.  Made an awful noise when I tried to start it, and they swore black and blue the vehicle had been test driven.   A disgrace.
  2. Hi Rice RAcing, I made a decision not to own a Toyota again which I will stand by... and as far as my nightmare with the blown engine. There are thousands of people who have heard about it. The internet is a very powerful tool!!! and I can guarantee that I have used it successfully. Toyota would have gained far more respect by the public if they accepted to rectify their faulty component which caused my engine to blow. Regards, Maba :)
  3. Hi Rice Racing, Hopefully not an empty promise!!! Good luck!! Regards, :) Maba
  4. Maba, Suggest that you may have some redress under the Trade Practices Act 1974. Statutory warranties, In short Manufacturers warranties are only Voluntary warranties, and after these warranties have run out you still have Statutory warranties. Manufacturers Warranties do not Negate Statutory warranties. If you contact your State Department of Business and Consumer Affairs, or The ACCC , on their web site, they may be able to steer you in the right direction. Good Luck, RTON LILL Hi, Fortunately the car has now been sold. I have completely lost confidence in the Toyota Brand and will never own a Toyota again. Regards, Maba
  5. Hi All, To put a long story short I was offered by TMCA 50% off parts only to rectify my blown engine which equated to almost $8,000 through TOYOTA. I had the engine done for $4,300 complete and satisfied with the outcome at the local mechanic with 12 months warranty. I persisted with TMCA & TMC to the point where Teresa handed over the case to the operations Manager George who basically tried to bully me away which didn't work. I had already made my decision and arranged for my vehicle to be rectified prior to that call. Its absolutely discusting that Toyota is taking advantage of customers in that manner especially when in my case it was identified by their team that the cause of my engine blowing up was due to a component failure and in your case its a factory fault. I would love to park my vehicle in front of a Toyota dealer (outside their boundaries) with a Lemon banner over it and start handing out flyers of my thead to potential customers. If I had the time I would do it... Anyhow I just blew off some steam . GOOD LUCK WITH YOUR ISSUE!!! Maba,
  6. Hi all, My 2001 Prado has been fitted with a second hand 2003 Hilux 5VZ FE engine with 80,000k's on the clock. I had a hard time finding a 5VZ FE engine out of a Prado with less than 140,000k's therefore the Hilux option was looking good. I have so far travelled 200k's since the engine was fitted and it runs beautifully (touch wood) Total cost was $ 4,300 which included the following, engine, fitting, full service/tune, Timing belt, Radiator flush (Toyota radiator coolant used)12months 20k Warranty on motor/6months 10k on labour, Free service/Inspection after 1000k's, Tow from home to workshop. To cut a long story short, originally TMCA investigated and concluded that they were not going to contribute to rectify the engine even though the cause was a Component failure (Con Rod) so basically I was told to "GO AWAY" I persisted through Toyota Japan who eventually through TMCA offered 50% off parts only, great outcome but when you receive the quote it didn't look to flash. The offer was based on a long motor $15,500 or short motor $10,100. Naturally I chose the quote for the short motor which came in at $7,500 offer incusive. I payed $3200 less than Toyota's quote, yes its not exactly comparing apples with apples but having sourced the right engine I think I am way ahead.. Regards, Maba
  7. Thanks Gav, Your advise confirms that I have made the correct decision. I'll keep you updated once I drive the car. Regards, Maba
  8. Hi All, I have made a decision to have the vehicle rectified using a second hand Hilux motor through a company who specialise in this field. I have sourced an engine with 80,000klm's which is currently being fitted. It was difficult to source an engine from a Prado with less than 140,000klm's but given that the Hilux adopted the 5vz engine in 2003/2004 etc it was easier to source an engine with less than 90,000klms. The only issue I had was the fact that when fitted into the Hilux the engine delivered only 124kw and torque was slightly less. After discussing my query with a number of mechanics they assured me that once the engine is fitted along with my original components and computer (there must be a technical name for this????) are fitted the engine will deliver the 132 kw and torque will adjust. Hope so!!!! If anyone has experienced the above scenario? l would appreciate feedback I will update the thread when I have picked up the car with details and given it a test drive... Regards, Maba
  9. maba
    My New Prado
    Its a petrol. We do around 8-10k per year thought it would be more suitable. If you are doing 8 to 10 k per year then make sure you service your vehicle very regular. Why you ask? If something goes wrong then TMCA will find a fault and refuse to fix it. Trust me I know. My engine blew up at 58,000klm's. I really stress this point out!!!! My issue continued for 3 months with TMC (JAPAN and TMCA AUST and all they persisted with is servicing. They believed that my vehicle at 58,000 klms required 14 services to be classified as on schedule. I know it sound unbelievable but its true. I finally achieved to get 50% off parts contributed to repairing the car but I refused the offer. Your car looks great!!! Color and all.Good Luck!! Regards, Maba
  10. Hi, I started this thread to allow members to share their experience with dealerships whether it being positive or negative. Post your story Regards, Maba
  11. Hi Kdeito, I am convinced that you and many others should not fork out any cash for a factory fault. Regards, Maba
  12. Hi All, The issue has now been resolved, TMCA offered 50% off the Warranty price of parts only. I have declined the offer and will be repairing the vehicle at my local mechanic at a lower cost. Thank you to all members who have supported me. Regards, Maba
  13. Hi, Keep persisting with TMCA, Maba,
