Its obvious that most of the guys on these forums have never driven or owned a fast front wheel drive car, which is not a bad thing just alot of important info to consider. This guy has spent a lot of coin but not in all the necessary areas to create a SAFE fast car... I was having a discussion with Northy and TC the other night about my own turbo setup on my sportivo and these are some very wise ideas that have lacked attention.......... Rule number 1: Fast FWD lack traction so upgrades must include 1.5way LSD + uprated clutch. Getting all that power to the ground is difficult at best and coming out of corners will light the inside wheel like a joke. Rule Number 2: Increased power usually means faster speeds and longer stopping distances so either bigger brakes or better pads, braided lines, synthetic fluid must be fitted (DOT requirement atleast) I am personally looking down the road of at least 4 piston fronts. Rule Number 3: Increased power +++ Decreased airflow by sticking massive intercooler in front of the radiator spells massive overheating issues. Any prolonged high boost runs equals heat build up the standard system wasnt designed to deal with. Anyways guys here is somethings to consider if you are looking at big power hikes and keeping a SAFE reliable car. The costs involved in setting it up right can be staggering!!!!!!
