acorn
    Kluger KX-S
1,351 profile views
acorn's Achievements
Enthusiast
Enthusiast (6/14)
  1. Thanks for the install info Hado, very informative and great photos too. I agree with Kesawi though - the microphone does look big. How does it look if you take the foam cover off? Does it use a standard 3.5mm mic? Gutsy effort though and thanks for sharing!
  2. *Quick update* Finally got around to installing my rear sensors. Big thanks to everyone for their help, especially Dave for his measurements - although I did modify the centre sensor dimensions from 90mm to 70mm (or approx 50mm if you measure from the top of the flat section of the bumper down). Visually 90mm looked too high for me. Overall I'm very happy with the install and the sensors work a treat. Install did take some time, but that was mainly due to unknowns on how to remove trim panels, determining wiring etc. For anyone interested I installed the control unit to the passenger rear side, below the plastic cubby box on that side. There's a rubber grommet perfect for bringing the wires in and an earth point right in this location. I tapped into the reverse +ve wire (from memory this is a blue wire) behind the access panel on the left, keeping close to the main wiring loom so as not to get in the way if/when I need to change the reverse bulb. I then ran the speaker wire behind the passenger side rear trim panel and placed this behind, just above the 3rd row seat cup holder. If you take a look there is a small access panel in this location. My speaker has two volume settings, low and high and an off setting, so being able to access it here is perfect. Speaker is currently set to low which is more than loud enough for me. If anyone has any specific questions just ask away - hopefully I can help.
  3. Hi Hado, Thanks for the updates and extra info on the system. How are you finding the unit after using it for a few days? I'm also keen to see your write up on iGO8 and how you got this running, features, usability etc. Lastly did you end up connecting the reverse camera to the flyaudio screen? Cheers! Edit - Another question, does the bluetooth automatically connect to your phone on start up? or do you have to initilise each time? Thanks!
  4. Hi Hado, thanks for the update. Look forward to your more in depth report. I'm keen to hear your thoughts on the sound quality, ease of use, functionality etc. Also, if you could explain your mic install a little that would be a huge help. Did you remove the trim cover on the A pillar or just press the cable in? I'm a little nervous with the airbag that resides inside...
  5. Hi udor, Picked up our Kluger recently and I'm experiencing the same issue - I tend to feel it through the brake pedal as you move into gear from a cold start. Feels like a rough shudder... then disappears when the vehicle is warm. I just had the 1000km service/check done and queried with the service manager. He suggested to start the car and let it run for 15 seconds while the oil pressure in the transmission builds up. I'd be keen to hear what other owners are suggested though. Cheers!
  6. Looking forward to hearing your thoughts on the unit Hado and Ham... oh and some pictures wouldn't go astray either ;)
  7. Thanks for the measurements Dave, and for the rear speaker pic BigBad64. Will report back again once the install is complete. Cheers!
  8. Hi Dave, Do you mind measuring the distance from the fold line on the bumper (just below the sensor) up to the sensor for me. Measuring from the ground up has too great a tolerance for me. I've tired different surfaces, fuel levels etc and I just can't get an even reading on both sides - seems to be a difference of about 8 - 10mm from left to right. Actually looking at the vehicle from the rear it seems to sit higher on the left than the right - the same as the measurements show. Thanks!
  9. Thanks SpeedRacer, the set I have is for a Mazda 6 too! Picked it up from ebay. I like your idea about the speaker location, although a little unsure about removing too much of the interior. Was this a problem or were you able to squeeze the wire between the interior trim and the carpet. Any tips for the connection to the reverse lights? Did you choose a particular side? Also, do you remember the wire colours you connected up to? I'm sure once I pull it all apart it will make sense. Thanks Dave, appreciate you taking a look.
  10. Thanks for looking BigBad64. Does it mention or depict the location of the speaker at all? Cheers!
  11. Good news on the switch Hado, thanks for sharing!
  12. Thanks Dave, that definitely helps. :) Interesting that there is a 10mm difference in spacing between the centre and outer sensors. Thanks again!
  13. Also, anyone that does have the rear parking sensors would you mind measuring the distance between the sensors and also the height - either from the ground up or a relevant location on the bumper. Thanks again! :D
  14. Hi guys, just wondering if anyone has a copy of the rear parking sensor install manual that they can share. I'm just about to install some aftermarket rear sensors and wouldn't mind knowing how Toyota likes to do it from the factory/dealer. I've found the front sensor install in a previous thread but no luck with the rears. Thanks in advance!
  15. Hi Hado, Have you received the FlyAudio unit yet or is it still on order? Please let us know your thoughts on the unit, quality etc. Also, how long did Toyota say the switch would take to arrive?
