feebee62
About feebee62
  • Birthday November 6
    Female
    Aurion Sportivo v6
    Road Trips
    Entertainment
    Computers & Electronics
    Arts & Crafts
    fiona
feebee62's Achievements
Explorer
Explorer (4/14)
  1. <_< Toyota Hinterland Nerang Q, replaced back o2 censor on my 2007 v6 Aurion sportivo and it hasn't be the same since, :o the fuel consumption is absolute crap, when put on the dyno o2 censor reads 15, when you rev it still stays the same is that right or should it go up and down with the idle, revs, etc P.S any one know of a Toyota aurion Sportivo specialist other then toyota that won't rip you off on the Gold Coast please !!!!!!!!!!!
  2. live love and laugh life is to short to be angry
  3. feebee62
    My pride and joy
    2007 Aurion Sportivo
  4. IF IT'S HELP MIGHT BE BECAUSE YOU HAVE TRIED more then 10 times and will need to go to toyota then bummer if that's the case good luck :)
  5. 3 digit code before carrying out the procedure. The letters SEC should be displayed on the radio. KEY CODE LAST 3 NUMS OF YOUR VIN 1. Turn the ignition on so that only accessories are powered. 2. Hold the TUNE ^ button and the 1 button at the same time until three lines appear. 3. Using the 1 button, press until the first digit of the code appears, using the 2 button press until the second digit of the code appears, using the 3 button press until the third digit of the code appears. 4. Hold the SCAN button until SEC appears on the display and disappears. The car audio system is now enabled. fOUND THIS IN ANOTHER SECTION HOPE IT HELPS IT DID WORK FOR ME
  6. RADIO CODE IF BATTERY FAILS YOU HAVE 10 APPEMPTS I went to check my code & VIN.NUM Guess what? It is the last 3 digits of the VIN. Toyota secret is unfold. OR 3 digit code before carrying out the procedure. The letters SEC should be displayed on the radio. 1. Turn the ignition on so that only accessories are powered. 2. Hold the TUNE ^ button and the 1 button at the same time until three lines appear. 3. Using the 1 button, press until the first digit of the code appears, using the 2 button press until the second digit of the code appears, using the 3 button press until the third digit of the code appears. 4. Hold the SCAN button until SEC appears on the display and disappears. The car audio system is now enabled. FOUND THIS ON HERE IN ANOTHER SECTION
  7. Traction control and engine light, came on after having them reset Toyota put it on the scope and said it was fine after being reset. has any one else had this problem What was the out come please How was it fixed??
  8. Hi every one need some advise about traction control light keeps coming on went to toyota and the put it on the scope and just recoded it drove round for 3 days and its back on any one had this problem and what did you do about it???
  9. Welcome to the Toyota forums feebee62 :)
    1. feebee62
      feebee62
      thank you Steve
