davo461
About davo461
  • Birthday 01/14/1941
    Estima L Aeras
    2002
    Computers & Electronics
    Arts & Crafts
    David
davo461's Achievements
Enthusiast
Enthusiast (6/14)
  1. So far , I have been unable to locate a towbar for my 2002 Estima. Being located out in the 'sticks' and not getting into Melbourne, I having been checking Gumtree and Evilbay; without success. I believe a Tarago one will fit but, I haven't seen one those, either. I phoned the importer, on advice, no dice. Any suggestions ? Davo.
  2. Greetings all fellow 'Steamers, Can anyone suggest a driving light setup for my 2002 Estima? I live in an area which is littered with the carcases of ex wombats and post kangaroos which make night driving a clear and present danger to my full body kit. The original lights are totally inadequate, in the standard form but, the fitting of additional driving lights seems to be a bit awkward.The full body kit presents some difficulty, it seems to me. Any suggestions will be appreciated. Also, is it practical/feasible to remove the rear seats, on a temporary basis. I admit that I have not had a 'in depth' investigation; just thought I would throw this question into the mix. I really love driving this beauty but, the thought of a heavy duty, animal type smack in the face, fills me with dread. I anxiously await the coming of wisdom. Cheers David Graham. Yarram,Victoria.
  3. Hi ! Alister. Thank you for your diligence. I looked at the photo of the Aussie one and it appeared that the breakout slot for the passenger side airbag was covered by the mat. I shall attempt to find some pictures of the Previa/Estima ones in UK and maybe order one from there. As an aside; I was advised, yesterday, that Armorall (?) is not the first choice for modern plastic dashboards, It is a sad day when you don't learn something new? Davo.
  4. Hi! All, can anyone tell me where to source a dashboard cover for my 2002 Estima? The Tarago one is different, according to my helpful friend at Auto Barn. If all else fails, I shall be forced to make one out of carpet and double-sided tape, bearing in mind the presence of the airbag. Nothing is impossible! Cheers, Davo.
  5. 72, going on 29!
  6. T.F.,thanks for that comprehensive info. I now have something to work with. Davo.
  7. Love is the missing word.
  8. The problem was finally solved; a Camry motor! The overall cost was only $4500; not much much if you say fast! I still my Estima and I still believe it was worth the expense. I am not sure if the Paki who sold it to me knew, or not. I prefer to think he did not. Davo.
  9. Being unable to make maximum use of the original radio/tv/gps unit, I am wondering what is available out there, in the market place. Does anyone have any advice or recommendations? Davo.
  10. This appears to be a common problem with these motors: Oh what a feeling! BUGGER.
  11. Thank you for your input, Robert. it seems tha a sensor at the bottom of the radiator, or somewhere near, had gone out.That problem has been sorted, along with some other stuff. I have a 20Mhz. FM Expander for the ICE but will have to check out more Oz friendly ICE units, a fair way down the track. Cheers, Davo
  12. Is there any chance of finding a used 2002 Estima towbar? New ones are a bit rich for my wallet. lol
  13. I also need this gear; it is very quiet here, isn't it? Surely soneone must know something.
  14. If you are lucky, it will just be a gasket replacement. If you are less lucky, it will be the above, and drilling/Heli coiling the block; expensive! If you are really unlucky, it may be a complete engine exchange; very expensive. I was, fortunately,one of the less lucky, it only cost about 2Grand; worth it, though.
  15. Can anyone advise me about getting a service manual, or at least, a wiring diagram for my 2002 Estima. Engine fans not running, checked everything is OK except no trigger voltage to fan relays. I would happily purchase a CD if I could find one.
