Posted (edited)
currently my set up is 17x7
im planing to go 16x7.5 running 215/55r16 et25
is this ok?
Edited by DuGong
is this ok?
Why you want wider and smaller rim ?
Insurance ...check with them ...
Road traffic Authority in State ....
Corolla Tyre Placard ..6jj or 7 jj
1 inch either side for Victoria 5 inch wide or 7inch ( change tyre placard to suit 17's and you can go 8 inch) Vicroads
Tyres may not be more than 15mm below or above tyre placard.. no current law for different size tyres on front and rear except AWD or 4WD must be same
and changes to speedo .....when you doin 96 actually doin 100kph
7 inch is perfect for the stivo plus legal. 7.5 fit but is a bit wide and usaually sticks out of the rim.
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
