C-one Final Gear Set for the 2ZZ Engine
14
Hi from Wagga
Engine oil dipstick reading
Landcruiser 13B Engine Swap
Hi I’m not shore how you went with this project but on a whim how did you go and do you still have the old 13b engine as I have this car and the engine failed looking for options cheers
