Twinky16v ae82
JayMan
hey guys been meaning to join for a while now.. thanks to the admin that accepted me anyways this is my close to stock twinky ..
some of you may know me from
www.twincam.org
www.ae82ownersclub.com
Owner:
John
Car:
AE82 Corolla Twincam 16 Hatch (88)
Engine:
Bigport 16V 4AGE red top 290,xxx kms
Engine mods: genie extractors
Drive train:
stock
Suspension:
Lovell springs, KYB shocks, front and rear Whiteline swaybars
Brakes:
AE101 brake upgrade with slotted DBA rotors
Bodywork:
not much yet seca front bar
Wheels and tyres:
ROH extremes 195/50/15" bridgestone GIII potenza's
Interior: stock very neat
DBA steering wheel
door pods
stereo gear:
Alpine headunit,
precision kelvar 6" component splits,
2X pioneer 305 12" subs
Future Plans:
strut braces and rear ae101 brake upgrade.. maybe some superstruts.
and a 4AGTE build up eventually, full respray and cut all the rust out
Edited by Twinky16v
luv them 4age's...
i owned a 86 twinky for 10 years, until last year...
mine had just over 450 thou k's, still going when i got rid of it...
keep us updated on your car...
welcome and enjoy your stay...
Edited by encounta
  • 5 months later...
hey guys i have updated the original post. alot has happened since then and alot of wok has gone into her shes slowly starting to become a pretty decent ride she looks pretty stock to cops besides the 15's which is good. i have some original side skirts but i dont think i will be using them
Tell me about it! lol
the heads ticking
valve steam seals are gone
the rings are gone
the thrust bearing and clutch are on the way out
cv is knocking
and she runs heaps rich
but i still get 400-480 km to a 50L tank with hard driving and for a motor that came stock 88kw at the fly.. 68 kw ATW isnt bad lol she still hasnt skipped a beat on me its great
just a quick update. upgraded to 2X pioneer 12" 305's soon to buy a new response amp and 6x9's when i make a parcel tray.
looks like im getting anew job with much better pay.. if i do i have promised myself a smallport in the next few months ;)
Guest fujiwara_tofu
4ages are wonderful arnt they.. they REALLY take a punishment ^__^
you stated about building a new engine... make sure to use an ae92 or ae101/ae111 block as its a lot more durable and have the oil squirters.
hope that helps.
hey mate i have a bit of knowledge on the 4age,
the bluetop bigport came with a 3 rib block that is quite weak but the REDTOP bigport (as i have are much stronger)
that said i am using a smallport for the very reason you stated above. they have oil squirter's and the oil feed to head is internal rather then external.. i have toyed with the idea of using a bigpport head on a smallport block but i am not to sure. i will most probably use a smallport head
thanks tofu
Guest fujiwara_tofu
for building an NA 4age the smallport head is proven to be better than a bigport up to around 200hp (NA).
i agree with u about using a smallport for those reasons also.
i use a smallport in my trueno... its lightly modded and has taken quiet the punishment... 4age are just so fun lol.
haha i love the torque less wonders :P
so you have read billzilla's notes havent you :P
when i get a smallport im just doing minor tweaks to it and dropping it in. next year a full rebuild and turbo conversion is taking place and iv started sourcing the parts already.. (thats why i have set up most of the suspension and brakes etc) should be seeing well over 200kw ATW luckily i have many friends that will look after me :)
Guest fujiwara_tofu
i HIGHLY reccomend a light weight flywheel,,, (i used a blacktop item and had it lightened), extractors and an airfilter, advance the timing.. they LOVE to rev with those minor mods.
i rebuilt my smallport and the compression is 11:1 (compression really helps these a lot i think)
yes i did read that artical.. its good isnt it... the bible of 4age LOL !
light flywheel was already on the list ;)
bigport cams
change all the seals so i dont have leaks
airfilter and extractors are already done
if for any reason i dont trust the head gasket.. while the head is off ill send it off to be rebuilt and she can run llike that untill im ready to go all out on her.
im getting the ae111 rear brakes to install maybe next week. :)
yes well a good H/G is a must.. when i replace the water pump ill get a genuine thermo stat and radiator cap.. at the same tie ill have the radiator unblocked.. (if i source an ae101 radiator its even better) just so im 100% sure my cooling system is working well.
  • 1 year later...
