NEW MEMBER 2007 COROLLA LEVIN ZR
hi all looks like this is the place to be if you own a corolla , just got mine last week , upgrade from an echo rush
bought a levin zr with moonroof and all the trimmings looking to mod it quite a bit in the near future . im having a lot of problems finding a k&n panel filter for it let me know if any of you have overcome this problem also need advice on how to get the stock headunit out as im installing a rockford 3sixty and aftermarket speakers and amplifiers, i do know my car audio just not sure which panel to try pull off first , any help would be much appreciated
Have you thought of keeping the stock head unit?
Stealth system is nice, and you get the benefit's of Blue Tooth - 6 Stacker, less prying eyes....
by the way do you have one of these cars if so have u changed the air filter to a k&n yet
I tried searching for a guide on how to remove the centre consoles for these new Corollas about a week ago with no luck. I don't think anyone has put up a guide yet.
With a bit of fiddling around and thinking, you could possibly find your way to removing the headunit. It doesn't look too hard compared to the bloody new Hondas which took me almost 2 days to figure how to remove the front console.
1) Remove the 2 lower silver side trims next to AC control
2) Remove the 2 upper silver side trims next to radio
3) Remove the AC air vent complete assy
4) Remove the radio surround
5) Then should be able to see 4 bolts holding radio in, just unbolt those
They got those new type clips so should be very easy to put out
Good Luck!
the usa 08 sedans look almost same as ours 2007 so maybe k'n have one for usa but you would have to proberly buy from USA ebay... or is the filter same size as 2006 shape?
Seeing K'N is based in USA try to contact them with measurments
I would at least break the car in before modding the filter aswell
And another thing .. as i found out as soon as headunit removed from car warranty on the units is GONE . i found out the hard way
Edited by DrivInGScHool
thanks guys or that , ive given up on the k&n idea and now have sucessfully removed the unit with no issues , just finished dynamatting the front doors and starting stereo install tomorrow
i can help you with the filter. get the ryco part number of the ryco website then ring rocket in sydnet it is 02 8825 1900 tell them the ryco number and you will be sweet
K&N Part 33-2360 = TOYOTA 17801-21050 DENSO
Edited by TZYKS
Yeah the headunit is very easy to get out, I to am also changing mine this week some time
Here's wat mine looks like before I put it in, I have a Pioneer 5950 and just a plain single din storage device
The Hammer
Edited by The Hammer
    2. 10
      front brake calipers
      Drive shafts
    6. 315
    7. 10
      Dashlight dimmer
      Electrical issues
