Caldina engine upgrade
callanr
Next to, if not, impossible. JZ series is RWD, Caldina 4WD drivetrain is front-wheel drive setup. Good luck fitting an east-west gearbox behind a north-south engine.
Or if you're wanting to do this in a Caldina, good luck fitting a north-south engine in a bay designed for an east-west one
i wouldnt bother with it but then ive seen a 1uz shoved in a caldina with a couple of turbos hanging off it
And I'll bet you that basically everything between the wheels and the engine was custom-built.
think that goes without saying but why would you need to go to such extremes on a car like that?
Because some people like things to be unique
Like the guy on Toymods who put a twin-turbo (and wants to add a supercharger) 1UZ into a ST185 GT4, converted to rear wheel drive.
Or the other one who put a 1UZ and full Nissan GTR 4WD running gear into a TA22
      1kzte throttle body
    4. 3
    5. 5
    6. 5
    7. 8
      PZQ60-00525 Issue
    10. 3
      Head Unit with Apple CarPlay
