Hi I have just bought myself a 2005 prado gx.
The headlights come on when the vehicle starts up.
Vehicle has been fitted with ignition on lights on would like to disconnect.
Any Ideas
Headlight switch not left on by any chance?!? If that's not the case, you'll need to do a bit of probing with a test light to trace the bridged circuit from headlights to ignition.
  • 9 months later...
Any Ideas
there is a little logic in there if the lights were left on and the vehicle stopped, the lights go off (so that the battery is safe).
then when you start the lights go on.
there is some functionality there about locking the car from outside using the security button.
I had same stuff in my camry 03
      HZJ78 TO HJ75 door compatibility
    2. 2
      Leaving a Camry Hybrid at the airport for 10 weeks?
    3. 5
    4. 0
      Is it possible for the 3.0L 1KD engine to be in a 2020 Prado
    5. 592
      JOKES !!!!
    6. 10
    7. 1
      rattle from the motor.
    8. 5
    9. 2
      A major Electrical problem on 2013 Grande
