Kluger's AWD system
boleh
The spec says "constant all wheel drive". Does this mean 50:50 front:rear torque split? Is this what subaru calls symmetrical AWD?
One dealer told me it was fwd then when traction was lost, rear wheels would come into play, but i have since read on this site it is 50:50. Which is what i wanted.
What a fookin' retard! That dealer should be shot for telling you that - AWD on demand applies only to RAV4.
Tell me about it, i try to find out and research the cars i intend to buy, and this is always useful, and get everything in writing...
  • 4 weeks later...
The dac button doesnt do that. Its always 5050. The dac can only be used in 1st gear low, to limit your speed downhill. hence why it is 1st gear only.
I dont know if it works in reverse, some other manufacturers DAC works in reverse as well, incase you need to...
Works both in forward first gear and in reverse also.
