Gday,
I want to get a 03-05 hilux space cab 3lt diesel and due to the fact they didnt make a space cab turbo was wondering what the engines are like once an aftermarket turbo was put on. To my understanding the turbo and non turbo engines are different. Does anyone know the reliability on an engine with an aftermarket turbo or if any changes are recommended ie. big ends, mains.
Thanks.
  • 4 months later...
Gday,
Thanks.
the turbo is really bad for that engine, its totally different and nothing will work. your pistons will blow out the top of your bonnet it will be worked that badly.
dont do it if you value your engine. supercharging is way cheaper and massive powergains! way better for your engine.
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
