Castrol Edge Sport 5W30 (special price $29.99)
lurry
  • 4 months later...
Don't think it would be a good idea to run this grade of oil in a 2zz. It's remains a little too thick at high temperature for such a high revving engine. (I just read an article on oil grades, etc in from VACC)
You're absolutely right. Just checked the lube guide on castrol's web site.
TOYOTA
Corolla Sportivo, 1796cm³ 2ZZ-GE Eng., 6-Spd. Manual (2003-2005)
Crankcase
CASTROL GTX MODERN ENGINE 10W-30 CASTROL MAGNATEC
Castrol Magnatec 10W-40 combines Intelligent Molecules with synthetic technology for a stronger layer of protection from the moment you turn the key. Whether its during start-up, or on the road in demanding driving conditions, your engine needs more than just ordinary oil. You need the advanced protection of liquid engineering. Castrol Magnatec keeps your car at its peak for longer as its Intelligent Molecules cling and bond to metal surfaces of your engine, protect during all driving conditions and temperatures. Castrol Magnatec meets and exceeds API SM/CF, ACEA A3/B3 requirements.
Service Refill Capacity: 4.4* Litres (See Note 568)
Manual Transmission
CASTROL VMX-M 75W/85
Mineral transmission and transaxle fluid especially formulated as a factory fill fluid for Mitsubishi vehicles and used in passenger cars, 4WD's and light commercial vehicles. SAE 75W/85, API GL4.
Service Refill Capacity: 2.3 Litres
Differential
Combined with Transmission
Power Steering
CASTROL PS FLUID
A mineral based fluid suitable for most power steering systems where the following specifications are nominated: Dexron®, Dexron® II & Dexron® III, SAE 10W or 10W-20 engine oil, ISO 32 or 46 hydraulic oil, Ford M2C-33 F/G, Ford M2C-138 CJ, Ford M2C-166H, Ford Mercon, Ford SQM-2C-9010A and Mitsubishi Power Steering Fluid.
(See Note 516)
Notes
* Includes Oil Filter
516 May also use CASTROL TRANSMAX M, CASTROL TQF or CASTROL TQ DIII.
568 May also use CASTROL EDGE SPORT 0W-40.
So what grade oil should i be running for sportivo, 10w40 or 0w40?
be careful with magnatec too. I've heard bad reports about it from a couple of different mechanics.
Im curious what do they say about it?
There's nothing wrong with magnatec. It doesn't belong in certain cars though that's for sure. Mechanics should read the label.
When I had my Sportivo I ran it on nothing but 5W-30 Edge. The recommended oil (the magnatec) was too thick imo.
  • 7 months later...
