aurion 18 upgrade
homer501
hey guys i found the perfect 18 inch tyres for an 18 inch upgrade 4 the aurion bridgestone re050a 235 45 18 the rolling diameter is the same as standard 669 so nothing will change dont even need a wheel alignment no speedo error also only 20 mil wider no insurance issues will fit 7.5 inch rim not sure on price yet let you know 2moro hopefully i can find some nice chrome rims i like . bridgestones are good as long as you buy the ones made in japan
Edited by homer501
When you change your tyres it is recommended you do an alignment. An alignment does not have anything to do with the rolling diametre. It makes sures all your wheels are pointing straight. Pretty much every time you jack your car up, hit a big pothole, drive up or park up on the kerb, your alignment gets changed a little. Over time this gets bad enough for you to notice the car veering off to the side. When changing tyres, you'd want to do an alignment so that you start on a clean slate and not scrub out one side of your tyres prematurely.
The Bridgestone RE050A are great grippy tyres, just dont expect them to last too long. AND to get those cheap, try Holden dealership/service department. Commodores have those tyres stock so they'll have plenty around.
      2000 Corolla Ascent - clock.
      ST205 for sale
      Rukus for sale
    5. 8
      CH-R sudden engine failure
      2Door 1975 KE30 Corolla 4Sale
      Hi from Wagga
    9. 12
