Post your ride heights
WaynoGTS
Car: 2005 ZZE123R facelift
Suspension: stock (3 years old, 60k km)
Tyres: New 195/55R16 (620mm diameter)
I've taken 2 measurements on 2 sets of flat ground:
Vertical from ground to guard:
Front Right 675
Front Left 680
Rear Right 690
Rear Left 700
Sideskirt ground clearance:
Front Right 190
Front Left 195
Rear Right 205
Rear Left 215
Center of wheel to bottom of guard derived from first measurement:
Front Right 365
Front Left 370
Rear Right 380
Rear Left 390
Difference between left and right is 5mm front and 10mm rear.
Difference between front and rear is 15mm on right and 20mm on left.
It would be good if i could get springs 20mm lower at front and 35mm lower at rear to go with new shocks, suggestions?
Anyone who wants to measure up and compare, post them up here.
Edited by Wayne123R
Suspension: KYB Excel G, King Low Front, Superlow Rear
Tyres: New 215/45R17 (625mm diameter)
Front Right 640
Front Left 640
Rear Right 640
Rear Left 650
Front Right 155
Front Left 155
Rear Right 155
Rear Left 165
Front Right 330
Front Left 330
Rear Right 330
Rear Left 340
Edited by Wayne123R
There is going to be an issue with measuring sideskirt clearance. The Levin skirts aren't as high, while people without skirts wont have that point to measure from. The main chassis rails sit lower than the skirts too. I do all my height measurements from ground to wheel arch, then check ground clearance to the lowest point of the chassis.
Ground to wheel arch isn't accurate either. Different rolling diameter of tyres and uneven tyre pressures will mess with your numbers. I think you're meant to go from the centre of the wheel/hub/spigot to the top of the guard to get true measurements of changes in ride height. Legally I think it's measured from the lowest point of the vehicle down to the ground. Anyway, for Wayne, as my eyes see it, I'm on TRD SusKit and my car looks about the same as yours with your new spring/shock combo. My brother is on TEIN Superwagon and is at least 15mm lower than yours all round, but without sideskirts.
    6. 21
    7. 21
    8. 21
