MsLevin
MsLevin
Is urs a levin or tivo?
neither of those im afraid ;)
as for your questions earlier, the only place i know with trd gear in aus is aaimotorsports. slimline weather shields are from toyota japan so you should be able to order them from toyota dealer like castle hill, check out the group buy section for more info. :)
i dont think they stock it but if you can find the part number, im sure they can import it in for you, but look in the want to buy section of the forum and see if people are doing group buys and see if you can work something out.
bk i think they were all referring to the 'ZZ weathershields.. it may be an entirely different story for the ZREs. go to any toyota parts dealer thats closes to you with the part number your after (if you can find it.. possibly on jap or euro forums?) then they should be able to source it for you.
i rang toyota in chatswood and also on woodville road and they dont stock it..
But they gave me numbers for two companys where they import shields from In NZ...
But i think most places only do fronts not backs...
