Brake Calipers
these are predominently sold from the US.
I ended up ordering them through monkeywrenchracing but i had to supply the part number
for the 4 piston set the number is RBK010.01 they are for the XRS corolla.
As mentioned u will need to get the disc's re-drilled as they are 5 stud over in the US.
Do you think they would fit the new 2008 Corolla?
How much did you look at for shipping and parts?
i havent looked into the dimensions etc etc of the brake setup on the new zre but i highly doubt that it will be compatible.
Look i could be wrong but i think its a very very very slim chance that it would work
checking out DBA and a few other sites i couldnt even find a listing for the ZRE which would help to see if these would fit.
I imagine however the caliper mounting etc etc is all going to be different since its a totally newly designed car over the zze12X
either way a quick google search renders a whole heap of results
here is just one of them
http://www.street-power.com/rotomafrbigb.html
