black smoke
your engine may be running rich when warm, rather than lean. i think your best bet is to get a good tune, and see if you can clean all the sensors on the intake.
for now, see if you can eliminate the easy stuff. buy a bottle of injector cleaner and put it in your next tank of fuel, and see if that makes a difference. it could just something as simple as dirty/clogged injectors, or dirty spark plugs that aren't firing properly.
    3. 21
    4. 21
    5. 21
    7. 3
      Selling vintage 1996 hilux
      2020 Corolla service question
    10. 7
      Help - Blowing white smoke
