Hi everyone, I have a 2.8 diesel hilux and have been told that the oil pressure is too high, has anyone heard of this and how to fix it. I have searched but cannot find any info. Thanks.
The hilux have a pressure relief valve around the filter housing which are commonly known to block when the motor is neglected. Before you get carried away with anything, you want to actually test to oil pressure at idle and f/t to determine you have issues. Are you using the correct oil grade?
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
