Posted (edited)
hey i just got myself a 88 sx cellica..... can someone give me some tips so i can make her go harder... wat can i do to her?????????? cheers
Edited by jazza
  • 7 months later...
nice car mate should of bought a turbo one if u ever sell yours and want a turbo one same model 89 model has the 3sgte motor in it so turbo this car will have u hanging on for dear life great fun but if not your car could some extractors and exhaust make sound heaps better go a little harder to
  • 2 months later...
hey. iv got 2 89 celica's and iv found with one of them. i drilled out the air box, it doenst make it go much harder it just lets it breath more and gives it a great sound!
how much harder do you want it to go? what motor is in it now..
if its a 3S-FE you could put a 3S-GE in it for a bit more power.... or if you have a 3S-GE and want alot more power you could do a 3S-GTE swap...
that said a motor swap is a big project to undertake... if you dont want to spend that kinda cash then you could start with the usual I-H-E combo (intake, headers, exhaust)
  • 10 months later...
You can always start with the little things, maybe put a pod filter on it, change the plugs and leads so they're new and you'll get better timing of ur air/fuel ratio. You know, overall basics of the car, later on if you want you can get an aftermarket ecu and an exhaust, depending on what you want, get a hi-flow cat etc.
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
