Putting a R151F in my 1998 ln167r IFS
I have seen a few video and bits and pieces of information floating around and just was a definitive yes or no. If yes, what kind of work/parts are needed. -
New member
Welcome to the forum Kathryn, happy to hear its running like a Toyota should..enjoy KAA -
Rav4 smart key keyless entry
The key proximity to open the door I believe is not an option for the GX and only available from GXL and up. For the GX only way to open door is by using the button on the FOB. -
Replacement springs for 2016 Aurion Sportivo
Kings springs catalogue doesn't mention higher springs ever existing. Custom springs might be your only choice. Sounds like a sports sedan with a body kit doesn't suit you anymore? Might be time to trade in for something else -
Hi, I am trying to find standard or raised height firmer than stock springs for a 2016 Sportivo. Does any one have a set for sale or know of anyone who still makes them or may have stock. Don't want to go to Coilovers , but need to raise the ride height slightly to save the front spoiler and stop scraping the tow bar all the time in parking lots and steep driveways. I need to replace the shocks now, and would prefer to do the springs at the same time, but there does not seem to be anything available Any help appreciated -
RAV4 19" wheels on Aurion
Layed down 4 coats of satin black, & 3 coats satin clear. Am quite happy with the finish, and a noticeable difference in comparison to the original black gloss. Can't wait to get 'em on the car 👍 -
1992 1hdt both blinkers flashing together
OK, pulled out the blinker control stalk and cleaned it with contact spray, problem still there. Disconnected the hazard warning switch and no blinkers at all. Not sure if the blinker relay gets its power through the hazard switch, if so this could be normal. It’s looking like a trip to the auto electrician as without a cct diagram I’m just chasing my *****. -
Alot of plant debri flying around today. Whipped up a spray booth. Not ideal, but it's what I've got to work with. Let the painting begin 👍
