Panel Beating
yeah hes right get a few quotes around sometimes other companies will try to do better i mean before i got that 400 dollar quote i had quotes like 1300 i wasnt too pleased about that... if your in brisbane i can prob recommend you to the guy i got it done from.
Someone hit my car, or kicked it! It is the size of a football and is about the right front wheel, above the guard. I been told i looking at a grand to fix it?
yes a good idea would be to get at least 2 quotes, if you own a zze i know the guards new from toyota are about $650 brand new, (not trade price) so you can see how the easily a quote can blow out to $1000.
going for the cheapest quote possible is not always a good idea also because there will be corners cut to make money, so the best advise i can give you is know what your getting and ask your self would you be willing to pay it..... in most cases $$$$ means youll get a quality job and always ask for a job sheet when you go to pick up the car so you know exactly what was done.
No way! $1000 is too much. My friend had a mother of a dent something with a fence post width and around 5cm depth and it was $500 to fix.
Probs shop around if your in Melbourne i can give you the name of the same panel beater.
Cheers!
Cheers!
like i said, the price you get quoted is determined by what will be done to the car
eg 1: repair guard and materials $250
primer and paint $100-150 (non blend)
painting labour $150 add $100 for blend
booth allowance $80
total: $580
eg 2: replace and fit guard $650
primer and paint $200 (includeing blending) if metalic a must
painting labour $200
booth allowance $80
total: $1130
these are very rough quotes but you get the idea
      maps in 2017 Camry Altise
    3. 5
    4. 4
      Front Cameras
    6. 51
    7. 51
      1kzte throttle body
      Aftermarket parking sensor
