Quick Suspension Question
Probably a n00b question but searched a few times and i need a quick answer...
what model corolla suspension is interchangeable with which, im after coilovers for a 05 sportivo but obviously sportivo is an australian name and does not apply internationally, so i want to know if 2001 - 2009 corolla suspension is all the same or what years corolla suspension will fit my car.
yeah i know that - but i need to know year like 01 - 08 or 01 - 06 etc... Thanks
Umm I don't think year is important.
You need suspension for the E12 chassis; for example ZZE122, ZZE123, NZE121.
Doesn't matter if its for sedan, hatch or wagon either.
Well, you can't have suspension from any model Corolla after 06...
Chassis for the Pre and Facelift are exactly the same, so anything in between 02-06 suspension set-ups will be fine...
and as long as they have the correct chassis codes, as And1 has shown ^
Evo
Hey im actually after the same BC coilovers except i want the BR series not the V1.
The justjap guy told me he can get it in ZZE130 chassis code.
does anyone know if this will fit the ZZE123?
Don't know if this would help or not, but lately I've been trying to look for Eibach Pro kit springs for my sportivo.
The thing is that the part number for the E12(zzE12#) corollas and the USDM corollas of the same year have different part numbers, so I'm not sure whether the part numbers have just been changed for some reason or they are in actual fact completely different parts. Maybe SD can shed some light on this matter as he appears to be the parts interpreter on this forum.
im a member on fordlaser and we did a groupbuy through wholesale suspension in blacktown nsw for the bc coilover range and im running them in my 323 sedan, can highly recommend the bc range i am runnning the new series top of the line thou :) they seem to know their stuff there, we actually ordered the bottom of the range gear and they upgraded us because they didnt have enough of the inferior ones :P handling and comfort to boot at the turn of a knob
