folding key case
gerds
Just bear in mind that if you plan on doing this, you somehow need to get the transponder chip out of the original key and into the casing on this one. The chip is sealed into the upper portion of the key and if you don't cut it right, you can damage it.
      Corolla Seca For Sale
      Toyota Corolla Sportivo
    6. 2
      Toyota Landcruiser problems
    9. 7
      selling car
