Bulb numbers.
goppy
hi all, im gonna do a total bulb swap, change to LED.
any pictures you's haveto compare the difference would be great, just post em up :)
if anyones knows the numbers/sizes of the LED bulbs i need please let me know.
(DJKOR) :P
ROOF =
LOWER DOOR =
INNER BOOT =
NUMBER PLATE =
MAP LIGHTS =
GLOVE BOX =
any help would be greatly apriciated.
thanks :D
(DJKOR) :P
ROOF = not sure on the exact size, i changed mine with a t10 converter (was a flat panel full of smds with a festoon (sp?) adaptor)
LOWER DOOR = t10
INNER BOOT = t10
NUMBER PLATE = t10
MAP LIGHTS = t10
GLOVE BOX = t10
thanks :D
added to that, if you wanna do your gearbox and centre consol lights, they are t5 led's
and maybe for next time, check this thread out http://au.toyotaownersclub.com/forums/inde...showtopic=19545
good luck :)
Edited by -DAvo
(DJKOR) :P
LOWER DOOR = t10
INNER BOOT = t10
NUMBER PLATE = t10
MAP LIGHTS = t10
GLOVE BOX = t10
thanks :D
good luck :)
bro, what the deal with the t10 adaptor? where'd you get this?
(DJKOR) :P
LOWER DOOR = t10
INNER BOOT = t10
NUMBER PLATE = t10
MAP LIGHTS = t10
GLOVE BOX = t10
thanks :D
good luck :)
sorry its a bit hard to explain... i will take a photo for you later tonight...
basically if you imagine a festoon bulb, which has two wires exiting from its centre, these two wires are connected to a panel of SMD LED's. thats about as best as i can describe it.
Here in perth they can be found in those little auto accessory stores which are usually full of HP increasing stickers/hello kitty mechandise etc :P
(DJKOR) :P
LOWER DOOR = t10
INNER BOOT = t10
NUMBER PLATE = t10
MAP LIGHTS = t10
GLOVE BOX = t10
thanks :D
good luck :)
like this man?
ROOF = 31mm Festoon x 1
LOWER DOOR = T10 x 4
INNER BOOT = T10 (1 only i think but why bother?)
NUMBER PLATE = T10 x 2
MAP LIGHTS = T10 x 2
GLOVE BOX = T5 (1 only i think but why bother?)
front parkers = T10 x 2
Gear and cig lighter = T5 x 3
The glove and the boot are a waste in my opinion.
You should do the Gear lights as well.
Gear light differences
With green condom
White LED SMD
can anyone tell me how to acess the bulbs? :ph34r:
I recommend using the forums search function. There are instructions around for each of the bulbs but in all honesty the interior bulbs are really so easy you shouldn't need instructions.
ok thanks anyway man.
    6. 21
    7. 21
    8. 21
