oil cooler
lylee
hey guys i went out and bought some stuff to make an oil cooler kit because i got bored yesterday
this thing was realy easy to install
took only 1/2 hour to completewith very basic tools so most people who know how to change oil and filter will be able to install
if anyone is interested send me a pm or add me to msn and i can have a chat about it
davoisgood@hotmail.com
I hope you put a thermostat in the cooler system, it's really easy to overcool a 1zz, even when turbo/supercharged
Thermostats FTW
A Permacool/B&M thermostat can be had for about $60, then add about $30-50 of fittings depending on what is used.
Had a look at the Davis Craig coolers; if you're using the tube and fin style (the snaking tube) they are no where as efficient as the plate and fin so might not be an issue.
    3. 14
      Hi from Wagga
    6. 2
    7. 2
    8. 2
      Engine oil dipstick reading
    10. 1
      Landcruiser 13B Engine Swap
