Recovery point
HappyCamper
If you are talking emergency towing, then yes - there is an eyelet (stored with the tools under the floor at the rear) that screws into the front bumper, details of which are in your owners manual.
If you talking a 4WD type recovery point for a snatch strap for example, then I would say NO; the towing recovery point would not be up to the task IMO and there are no other towing points on the front.
Hope that helps!
I tried to track down a recovery point for the Kluger when I first bought the car through various 4WD accessories companies. I could not find an off the shelf product for the Kluger as it is not considered a 4WD and therefore not in need of a recovery point. I was told that I would have to arrange a recovery point to be designed by an engineer and then fabricated.
