LED lights for Licence Plate
Ronnyboy
Hey Everone,
Does anyone know where i can get a decent set of Bright LED lights for the Licence plate?
If possible, i want a set that also lights up the ground. :)
http://www.brightlightautoparts.com/LEDReplacementGlobes.html
highly recommend them
they may look cheap, but their leds are WHITE. not yellow, purple or blue.
WHITE
they also havea shop in vic.
Thanks,
Might order them from here, :)
I just have to find out what size and shape bulbs i have for the licence plate.
cool. make sure you order the wider angle ones.
i ordered the shorter and these wider angle types, and must say the wider angle suit more to license plates since they project 120degrees.
http://www.brightlightautoparts.com/files/T10LEDI2P.pdf
    3. 14
      Hi from Wagga
    6. 2
    7. 2
    8. 2
      Engine oil dipstick reading
    10. 1
      Landcruiser 13B Engine Swap
