Perth Cruise 07/08/2010 (freo to toodyay)
14
Hi from Wagga
Engine oil dipstick reading
Landcruiser 13B Engine Swap
Hi I’m not shore how you went with this project but on a whim how did you go and do you still have the old 13b engine as I have this car and the engine failed looking for options cheers -
hi I have a 1992 RN105 22R with a G52 box, can i use an automatic gearbox from a donor vehicle (1991 4runner 3vze) and make it work in my manual ?
