KX-S Headlight Adjustment
miyage007
Hi. Does anyone know how to adjust the vertical position of the KX-S headlight? I've been trying to adjust the low beam down a bit by turning the bolt/wheel cog located on top or near the H4 bulb but it doesnt seem to have any effect either counter clockwise or clockwise. There seems to be 2 wheel/bolt adjustments that I can see at the back of the enclosure. Top (I think is for vertical) and bottom for horizontal positioning. I turned both but has no effect. Is there something that I may have missed? Thanks.
      help with clutch
    2. 3
      newbie from Queensland
      High mileage camry
      1981 Hiace ignition upgrade
      Aftermarket Air Intake
      Heater problems
      Entertainment Unit Upgrade
