ACV40 Camry Cust Service Excercise
Adamsy
Hi Guys just thought i'd share this with you.
Just Like Aurion this one only affects the face lifted Camry model owners.
Due to the sealing gasket composition, over a period of time under certain environmental conditions the possibility exists for the silver surfaces in the LED's in the rear combination lamps to experience corrosion. This is in under the influence of humidity and higher atmospheric temperatures, the gasket used to seal the open tale lamp and the vehicle body can emit small amounts sulpuric acid (H2S) Affecting the durability of the LED's. As a preventive measure Toyota Australia will conduct a customer service exercise to replace the RH & LH rear lamp Gasket.
So nothing to major and affect vehicles built from 30th May 09 through to 14th Jan 2010. P/N:04000-51106
Please note that this DOES NOT involve/effect Hybrid Camry AHV40.
Owners will start receiving letters from Toyota about it in the next couple of days. Hope this helps
      ZRE182 Nudge bar
      2016 Hilux SR5 Coolant Issues
      What to say!
    7. 4
    8. 4
      RATTLING CAMRY 2013
