Guest GTI POWER
Hi all did a search and cant find the info that I'm after,
just wanna know if its safe to fill unleaded e10 for my 2002 corolla Levin ?
in my log book it doesn't say anything about e10 because it wasn't out back then
any info would be great cheers ...
Water and oil/petroleum spirit do not mix
Water and alcohol (ethanol) does and that is the unmanageable problem
When ethanol was first released, in our sometimes humid climate, an unacceptable amount of moisture was absorbed and vehicles were breaking down
These days ethanol is added at a later stage and more care is taken to keep atmospheric humidity out
In older vehicles, seals which work reliably with petrol and oil, slowly dissolve/break down in ethanol
Modern cars have seals designed to cope with ethanol
I use 95 octane fuels in my Camry, as 95 and 98 octane fuels give better economy the extra cost is less than it appears
The computers in modern cars adjust to the use of the better quality fuel and an improvement in drive-ability can be noticed after a few tank fills
I've managed to work out that using e10 petrol is the same as using say 95 or 91 unleaded. why? because ethanol does lesser mileage requiring you to fill up more often than filling up with 95 or 91 unleaded, thus the costs are the same. It might hurt the pocket to fill up with 95 or 91 unleaded but it lasts longer and you fill it up less frequently... and you also get more power. :)
91ulp is still cheap, not worth the trouble..
      Android auto
    2. 9
      Android auto
    3. 1
      Turboed Corolla Overbuilt?
    4. 3
    5. 3
    6. 0
    7. 18
    8. 5
      Tow bar
