We have fitted rear disc brakes to the paseo. New rotors new pads but could not get a caliper kit in time for instalation. Hand brake was woeful left hand caliper stuck off, We got the caliper kits which we fitted today ,the brakes are working beutifully on the peddle but the hand brake is worse than before. There were no obvious problems re bores of anything (pitting). The left hand caliper had what looked like a new piston. As it would seem to be a mechanical fault and we put it together the way it came apart would like to get a exploded diagram of the caliper internals to check they were put together properly last time.
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
