Wheel spacers
Hey guys,
I'm planning to buy hubcentric wheel spacers but i have no idea what the bore size is lol.
how do i measure it, or do any of you's know?
I got a 2009 zre corolla sedan.
Thanks!
You measure the hole in the rotor
Mine were 55 mm I think
But my spacers are 54.1mm
Go to the website of the group who make the spacers
And you should be able to find some for your car
I put 15mm spacers on my 98 Celica but I had put on Volk TE37's
These were off a Subaru and were 46 offset instead of my normal 42
This is why I said I had 11mm spacers
Theres another idea
Get some Volks off a Subaru
Best wheels you can get
Though many Subarus are 50mm in which case you could use a 20mm spacer?
For a 30mm offset
I think thats as far as you could go without fenders and steering problems
Edited by Excalibur
Are you putting on shim type ones or proper spacers?
Hubcentric means proper ones I presume with studs?
I wouldnt go bigger than 10mm or your steering might get a bit stiff
esp if you have 7.5" rims
You will also need to run a high quality tyre like a Toyo to lighten your steering
And get an alignment done after as it does change your geometry
But yeh, I have 11mm and they are the bees knees
My car feels wider and handles fast corners way better
Suspension is also softer now
Mine are G racing from Taiwan
Very good with 0.05mm accuracy
I did need to grind my studs down to fit my rims on..no worries
Edited by Excalibur
I remember one of my spacers was harder to get on as they are tight
And I needed to sand the rotor surface a lot on one hub to get the rust off
And also around the actual hub itself until the spacers sat flat
We then checked them by running a 1/2000 feeler blade around them
After that they were fine when they were removed
But Im sure your car wont have the rust like my 98 model
But we did need an impact driver to undo the nuts as they are
Thin and hard to grip onto with a power bar and socket to remove
Edited by Excalibur
Have a look at this thread from Toyotanation for a 2010 rolla xrs
You may need to get your fenders rolled (not hard and looks cool?)
Also I remember that 15mm is the smallest size they make for a proper hubcentric spacer
But I have seen BMW racing cars with 10mm shims
These are WAY lighter and will not rob you of power
I saw them on bimmersport
If you go for shims and longer studs
Make sure you get proper high tensile racing studs
http://www.toyotanation.com/forum/sh...d.php?t=352430
Edited by Excalibur
I was thinking..
Dont let that thread from toyotanation put you off
Those guys might be freaking out about nothing
which I find is often the case on these sites
You prob. know your wheels arent supposed to come out past your guards
One way would be to put a spirit level alongside your wheels
and a ruler to measure how much space you have
      1989 Hilux Low Voltage
      Ae92 genuine low ks 70800
      Code P004B
      Upgrade from 2012 to 2023
    9. 3
      Towbars
    10. 5
