Micks super mega awesome garage cleanout
IF YOU ARE AFTER SOMETHING YOU DONT SEE HERE, JUST ASK!
So I have a LOT of celica/corolla/mr2 related parts i need to get rid of, and I figure that people may as well get some use out of them rather than it going to scrap, so here we go.
many items now on ebay;
http://shop.ebay.com.au/mick.wheelz/m.html?_trksid=p4340.l2562
ENGINES/GEARBOXES:
4A-FC engine + gearbox - $50
It has wiring loom, intake mani, carb, etc. Is missing cams, covers, exhaust mani.
3S-GE bottom end - $10
mostly complete short motor, suit rebuild.
5S-FE bottom end - $50
rebuild, with some accessories.
C52 Manual Gearbox - $50 SOLD PENDING PAYMENT
out of an AE82 SX, 150,xxx kms.
S53 Manual Gearbox - $50
Out of a ST184 celica, would suit camry, 200,xxx kms.
ST18x Celica / SW20 MR2 PARTS:
ST18x Tailights - $20ea
good condition, RHS has small scratch. Includes clip in fins.
ST18x glove boxes (x2) - $10 ea
good condition
ST18x factory strut braces (x2) - $5 ea
good cond, black
ST18x radiator - $20
some bent fins on back, not clogged, with themofan
ST18x under cluster/key barrel surround - $5
good condition
ST18x rear plastic - $5 ea
good condition, piece where doors would be if it had them
ST18x boot hatch plastic - $5
covers the wyper motor/etc
ST18x cupholder - $5
sits under the radio, works.
5SFE starter motor - $40
rebuilt solenoid, good cond.
ST18x alternator - $40
was working when pulled.
ST185 oil pan - $20
good cond, no dings, would suit 5SFTE project.
CT26 factory oil drain - $10
metal oil drain for CT26
CT2x braided oil drain - $50
Oil drain using braided hose (-8an drain, -4an feed) comes with hose and plate to suit CT2x
ST18x air piping - $5
sits under the steering wheel
3S-GE Intake manifold - $20
would suit 3SGTE wanting side tb
3S-GTE intake manifold - $20
painted red
ST184 Instrument Cluster - $50
180,xxx kms, was working when pulled. Good upgrade for ST185s
3S-GTE ECU (x2) - $50 ea
2x JDM ST185 Celica ECU's
ELECTRONICS:
Greddy Emanage Blue - $300
Includes programming cable, harness, software
Blitz MSTT Turbo Timer - $25
no harness included, will need to be hardwired in.
Pioneer DEH-2850MP CD Player - $80
Plays MP3/WMA CD's, has sub output, good condition includes harness
AE Corolla / AW11 MR2 Parts:
4A-GE Intake Manifold - $20
good cond
4A-GE TVIS plate - $5
good cond
AE8x corolla stater motor - $25
4A-x Sump - $10
good cond, no dints
4A-GE coil - $10
4A-FC alternator - $20
AE92 GTi instrument cluster - $75
Includes voltage, oil pressure, etc
4A-GE ECU - $50
from AW11 MR2 (AFM, not MAP)
AW11 MR2 Wiring harness - $50
full harness, uncut
NOTE: All parts sold as is, where is. No guarantee or warranty given. I am not liable for any damage to property or injury caused. Upon purchase of these items you agree to the above conditions.
  • 4 weeks later...
  • 7 months later...
      Towbars
    2. 5
      ASV50 Camry Head Unit Options
    5. 2
    8. 14
    9. 2
      Hi from Wagga
