Just a quick question
If you're after an actual flywheel, you can use any 4age flywheel, you just have to get a matching 4age clutch for the particular flywheel you choose. The GZE setup will not fit a C series gearbox.
If it's just a clutch you are after to go with the stock 20V flywheel, the 20V clutch is exactly the same as the AE93 SX corolla clutch from the 100kw smallport 4age. referred to as the 212 or 215mm clutch with a C series spline depending on which clutch catalogue you look at. It is NOT the 200mm 4age clutch from the AE82 Twincam.
Edited by rollamods
this might be a stupid question but did the ae93 come out in australia :blink:
    6. 21
    7. 21
    8. 21
    10. 3
