255mm-275mm
2204
corolla 255mm front rotor
corolla sportivo 275mm front rotor
what is needed in order to fit the 275mm rotor on a normal corolla, would it be worth it in the end?
only reason is because my rotors are due for a change soon so might change them to 275mm slotted if possible, if not then just 255mm slotted.
Edited by 2204
I'd assume the calipers to fit over the new rotor with new pads. Hub more than likely is the same.
I'm on my iPhone so I can't see your info on the left what car you have?
2006 toyota corolla ascent
You don't need the caliper itself. If you use the calpier bracket from a celica or a sportivo you can use your current caliper. You will need to use sportivo/celica pads though from memory. Test fitted my bracket to DHC09's car years ago out of curiosity. Otherwise you can design a dog bone and have it machined to space your current setup out by 20mm.
lets just say if i have the sportivo calipers, the 275mm sportivo rotor with pads to suit would it fit straight on my exisiting hub with no work needed?
    6. 21
    7. 21
    8. 21
    10. 3
