bigger injectors???
anponee
i was thinking of getting bigger injectors for my 5sfe but have no idea on it.
just want something to fit straight in and around 350cc???
thanks for all help in advance!!!
  • 3 months later...
I checked new injectors out and ended up phoning the states. There were some risky side effects at changing them and I was told my injectors were good up to 300hp
Well I can tell you the 5S ones aren't even good enough for 200whp if you are still running stock injectors.
Each standard 5S-FE injector is good for 42.6hp(at flywheel) at 100% duty cycle. You have a ST202 that runs a 3S-GE with VVT-i, am I correct? If so things are very much different.
Also your power figure is 197hp at the flywheel as well.
If you are going to turbo a N/A engine, no matter what it is, you ALWAYS need to upgrade the fuel system (pump, injectors, etc)...
if you want to do it properly that is...
    6. 21
    7. 21
    8. 21
