Hi my sons 94 ZR is using coolant.
I cannot see any leaks and no milky colour in oil.
Are there any know areas i should look at?
It has anew radiator, one thing i have noticed is that fans for the radiator start immediately the car is turned on even when from cold is this normal?
Darren
The fans starting could be due to a broken or disconnected temperature switch (its in the bottom of the radiator).
Is the car blowing any smoke at all, white smoke could indicate a head gasket issue.
Is the over flow bottle pressurising or boiling? when was the last time the cap was replaced?
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
