1994 ZR Using Coolant
XR8320
Hi my sons 94 ZR is using coolant.
I cannot see any leaks and no milky colour in oil.
Are there any know areas i should look at?
It has anew radiator, one thing i have noticed is that fans for the radiator start immediately the car is turned on even when from cold is this normal?
Darren
The fans starting could be due to a broken or disconnected temperature switch (its in the bottom of the radiator).
Is the car blowing any smoke at all, white smoke could indicate a head gasket issue.
Is the over flow bottle pressurising or boiling? when was the last time the cap was replaced?
      Rav4 smart key keyless entry
    4. 13
      Starter motor issues
    7. 3
    8. 3
